Engine Ruff Idle Wont Go Away
So Far I have replaced all parts with Mopar Parts from dodge. Fixing the Plenum is on my list of do's... Bigger Issues? I just went for a road test last night and now I have an issue with Reverse again. Very skipping trying to back up? It was fine after adjustments. I'm now at the point to maybe retire the truck..(Money Pit)...Thanks
Not so good NEWS... I just dropped my Trans pan and Valve Body...You can smell the burnt fluid and I noticed the rear bad is gone... The adjustment was right to the end...............Start looking for a garage.....$$$$$$$$$$ Oh Dear
Not an inexpensive proposition. Don't spend more than 1500 on the whole job. See if you can find a shop that will let you supply the parts, or at least, specify some heavy duty parts.....
Could be burnt, cracked or sunken valve seat and new sensors won't help. Compression test done yet? Or a leakdown? How many miles on truck? I wouldn't commit money on the transmission until the motor issues are resolved.
