Timing Chain Sets
Old Sep 23, 2014 | 01:36 PM
Spillage's Avatar
Spillage
When all is said and done, there are plenty of other things that will make more noise than the timing chain.
Wind noise from the mirrors is one.
Old Sep 23, 2014 | 09:16 PM
JSTMoto's Avatar
JSTMoto
Originally Posted by Arde
I've heard that the gaskets they supply are sub-standard, get a Fel Pro intake gasket set. The only bolts that must be replaced are the intake manifold bolts, the rest are reusable. Don't know what's in their kit, but if it doesn't include man. bolts, you'll have to get a set.
Hughes kit includes new intake manifold bolts, and plenum plate bolts.
OP, you'll want to pick up a tube of blue thread-locker for the plenum bolts though. That isn't in the kit.
Old Sep 23, 2014 | 10:20 PM
topkin's Avatar
topkin
Has there been a common experiance here on the hughs gaskets failing?
So i'ts looking like I need to order Comp Cams Double Roller Set, the timing gasket set, tensiouner if I have the funds, some thread locker, spray some bolts with PB blaster for a week and I should be looking golden..... probobly won't get to it till next weekend.
Old Sep 23, 2014 | 10:57 PM
topkin's Avatar
topkin
I ordered the Comp Cams Double Roller set and a Fel Pro timing gasket set. $68 total on amazon. I'll pull the trigger on a fel pro kit for the intake manifold, but id rather not if the hughs gaskets will be okay.
Amazon.com: Competition Cams 2103 Magnum Double Roller Timing Set for Small Block Chrysler: Automotive Amazon.com: Competition Cams 2103 Magnum Double Roller Timing Set for Small Block Chrysler: Automotive
Could someone give me a little education the the 4* maximum advance/retard. Is this something I would want to consider playing with
Amazon.com: Fel-Pro TCS45999 Timing Cover Gasket Set: Automotive Amazon.com: Fel-Pro TCS45999 Timing Cover Gasket Set: Automotive
Old Sep 24, 2014 | 08:51 AM
I think the hughes kits now actually COME with a fel-pro gasket set...... check on that first, just to verify.
Old Sep 24, 2014 | 06:35 PM
Spillage's Avatar
Spillage
The Airgap kit I got earlier his year had "Made in India" gaskets.
I bought my own FelPro.
Old Sep 24, 2014 | 09:42 PM
xplorer82's Avatar
xplorer82
I went with the S.A. double roller. great fit, quite, great price with the advance auto online discount code.
the comp cams should do you good. I was looking at that one too, just didn't want to wait for shipping or driving 45mins to Summit to pick it up.
glad you went w/Felpro intake gaskets.. Ive bought 3 Dorman intake gasket kits and everyone had HORRIBLE intake gaskets. Unusable. no quality control. So I have 3 sets in the garage, opted for Felpro intake gaskets for all 3 trucks.
Quick tip....... to keep all timing dead on, there will always be tension on the chain (one side will be loose while the other side of the chain will be stiff), take your socket and give it a tiny turn to put slack in the side that is stiff. That way when you pop off the chain and sprockets it doesn't turn on you (even tho it wouldn't turn much)
Happy wrench'n.
Old Sep 24, 2014 | 09:46 PM
JSTMoto's Avatar
JSTMoto
I used the Hughes intake gaskets and no problems so far. I did use some non-hardening sealant around the coolant ports.
Old Sep 24, 2014 | 09:54 PM
xplorer82's Avatar
xplorer82
I used Copper RTV around
coolant ports
corners of timing gasket/oil pan gasket
front and rear rubber intake gaskets
water pump I always use the (blue) water pump/thermo rtv.
Old Sep 25, 2014 | 12:10 AM
Twmays's Avatar
Twmays
No.
Timing is controlled electronically by the PCM. I advanced mine 4* and everything ran the same- no discernible improvement. Now that I'm having some (apparent) timing issues I'm wishing I hadn't used the advance key way, just for peace of mind.
