46re speed speed sensor?
Old Sep 24, 2014 | 11:44 AM
justinr678's Avatar
justinr678
Default 46re speed speed sensor?
Hey guys. I'm writing this as I'm burning brush piles in a field so bear with me as I'm trying to not start a forest fire. My 98 Ram has around 190,000 miles. Motor is still going strong. But I've been through 4 trannys. Yes FOUR. Everything seems good but I have a feeling a sensor went out. Recently the truck does not like to upshift to 1st gear at stop (say a redlight) but I can manually shift it to 1st and 2nd no problems. I've also noticed my speedo has a bit of a delay. When I'm driving you can see the speedo go from 5...10...then if I get on it, stays at 10 then jumps up to my actual speed. Any ideas if it's the Speed sensor? I have a code reader at home but I'm not sure it would even throw a code. Ideas? Thanks.
-Justin
Old Sep 24, 2014 | 12:02 PM
Speedo gets its cue from the rear wheel speed sensor on top of the rear diff. Not sure if that is your problem though, sounds more like just a sticking needle..... (not sure what can be done about that....)
When is the last time the filter in the trans was changed?
Old Sep 24, 2014 | 12:07 PM
justinr678's Avatar
justinr678
I changed the fuild and filter when I replaced the prussure sensors..Around 1000 miles ago.
Old Sep 24, 2014 | 12:14 PM
Check fluid level again. (have to check in neutral, park will give an artificially high reading)
Did you also adjust the bands?
Old Sep 24, 2014 | 12:21 PM
justinr678's Avatar
justinr678
Fuild is still in 'safe' I didn't adjust the bands. I haven't had this particular tranny for more than 4000 miles of at most. So I didn't think it would need it.
Old Sep 24, 2014 | 12:25 PM
Replacing the rear wheel speed sensor is pretty easy, and not hideously expensive..... it *might* deal with your issues, but, I wouldn't bet heavily on that.
Old Sep 24, 2014 | 12:32 PM
justinr678's Avatar
justinr678
any ideas on the lack of 1st gear at stop? It upshifts if i hammer the gas. But not on its own.
Old Sep 24, 2014 | 12:39 PM
Its *possible* the PCM doesn't think you have stopped yet...... if the speedo is still reading 5mph or so..... aside from that, I am not sure what else would cause it..... you have already replaced the important sensors in the trans....
