Installed projector headlights. Now have turn signal issues, when the lights are on.
Old Sep 25, 2014 | 12:19 AM
timrlyon's Avatar
timrlyon
Default Installed projector headlights. Now have turn signal issues, when the lights are on.
I have a 97 ram 1500 sport. I installed spyder projector headlights and I have had a few issues since. The main issue is that when I have the lights on the turn signal is extremely slow. The turn signal will be on for about 4 seconds then off briefly then back on for 4 seconds. When the lights are off the turn signal is slower than it used to be but not really an issue. Also the fog lights no longer want to turn on when i try to turn them on. Not sure if the issues are related.
These are the headlights I installed.
http://www.carid.com/1997-dodge-ram-...-25511049.html
Thanks.
Old Sep 25, 2014 | 09:34 AM
Did you reuse the stock turn signal bulbs.
Old Sep 25, 2014 | 04:34 PM
timrlyon's Avatar
timrlyon
Yes i did re-use the stock bulbs for the turn signals.
Old Sep 25, 2014 | 05:50 PM
They should work just the same then.... maybe the flasher unit is just getting tired?? Do all the bulbs work?
