Possible axle swap?
Old Oct 13, 2014 | 07:58 PM
sam3293's Avatar
sam3293
Default Possible axle swap?
So i have been having a problem with gettin my truck over 70mph before it shakes like crazy. Before i couldnt get it above 60mph but i replaced te steering components to moog now it drives straight and the vibration moved a bit. When i relase the gas above 60mph i get a vibration from the rear but when i repress the gas it goes away till i hit 70 mph.
I found a 97 dodge ram parts truck that icould buy it already has the axles swapped to a dana 60 front and dana 70 rear wonderin if they will work for my 99 dodge ram 1500.
Thanks for the input.
Old Oct 13, 2014 | 08:27 PM
There are some minor differences.... but, I think, they should work. Springs on the heavier axles were wider.... so, measure the springs, and see what ya got.
Old Oct 15, 2014 | 10:32 AM
sam3293's Avatar
sam3293
One more question.
The other guy didn't pan out.
New truck 99 Dodge Ram 2500 short bed.
Dana 60 front Dana 80 rear
I got a price of $500
For the two axles, leaf springs, shackles, coil springs, tires and rims, and read drive shaft.
Anything else I need from the donor? And how is the price?
Old Oct 15, 2014 | 11:01 AM
Ham Bone's Avatar
Ham Bone
Try and grab the t case also. Dana 80 means it was probabbky a diesel and probably has the 241HD
You HAVE to get the leaf spring hangars if you wanna use those springs.
I doubt he will want to beat the frame rivets out to give you the hangars.
You could buy universal ones. But they are expensive about 200.
Old Oct 15, 2014 | 01:45 PM
sam3293's Avatar
sam3293
The guy says the truck has a 5.9liter so its not a diesel. And the trasfer case is shot.
Old Oct 15, 2014 | 02:55 PM
Then it probably just has a D60 rear. (unless it is the diesel... that was also 5.9 liter. )
Old Oct 15, 2014 | 03:35 PM
sam3293's Avatar
sam3293
So my transfer case will not work with a dana 80. So I would have to find another one or hold off for a dana 70
He verified its a gas 5.9l
Old Oct 15, 2014 | 03:51 PM
Ham Bone's Avatar
Ham Bone
your stock should work just fine
if it was a diesel i think the 241DHD has a different spline count.
if so you just need that u joint that is the larger size on two and the smaller size on the other. Then you can use your stock slip yoke with the 2500 driveshaft
Old Oct 15, 2014 | 04:59 PM
sam3293's Avatar
sam3293
Ok thanks guys guess I'll pick them up fri or something.
Just heard from the guy again. Apparently he missed the fact the front axle is cracked down the middle so looks like I'll keep searching thanks for the help.
Old Oct 16, 2014 | 09:12 AM
Gas engines, even in one ton trucks never came with the D80..... that's got to be either mis-identified, or, it has been replaced in the past. Also, I think all the D80's were duallys, weren't they??
