Throttle Valve Cable Replacement? '01 2500
Old Oct 25, 2014 | 08:17 AM
xplorer82's Avatar
xplorer82
Originally Posted by BenB010
After taking a look at it earlier I found that I overestimated the complexity of the replacement. I found exactly what you just told me. I was unable to get the end off the stud, nor could I get the plastic tab out of the metal slide. I'll be back at it, properly equipped, tomorrow morning. Hopefully I'll be able to get it out. Thanks for the reply!
your welcome.
the end of the connector on the ball stud just pops straight up. take a small flathead and place underneath it and press up. it is plastic so not too hard. it should pop off with a little force and wiggling.
to get the transmission side of the cable out of the mount there is a little black tab you have to either lift up and slide it out, or press it in and slide it out, I cant remember off the top of my head.
to get the throttle body end out of the mount/holder, there are little tabs, just press one in, push it back a tad, then push in the opposite side and it will pop right out.
Old Oct 25, 2014 | 12:19 PM
BenB010's Avatar
BenB010
I finally got it all out and the new cable in, but as life goes there's a new problem. I went to start it up and it chugged a bit and started and then died after about 5 seconds of running poorly. Waited and tried a second time, chugged and didn't start. Waited a minute or so, tried and it didn't even chug it just sound lie it was grinding a bit. So I said no more for me today. Any ideas?
Old Oct 25, 2014 | 12:53 PM
Hold the gas slightly open while cranking.
Old Oct 25, 2014 | 06:02 PM
BenB010's Avatar
BenB010
I tried again but even without giving it some it sounded more like the battery was dead this time around. But it seemed stronger than a dead battery and wouldn't catch at all. My buddy though lt it could be my alternator when I told him the initial sounds.
Old Oct 25, 2014 | 06:45 PM
give it a jump, see if she'll start.
Old Oct 26, 2014 | 09:14 PM
bjr1a's Avatar
bjr1a
try and see if this clip will work without replacing the entire cable....
Amazon.com: atp automotive YR-100 Detent Cable End: Automotive Amazon.com: atp automotive YR-100 Detent Cable End: Automotive
Old Nov 11, 2014 | 01:17 AM
BenB010's Avatar
BenB010
Had a buddy jump the truck Saturday morning and we got it running. Let it run for about 10 minutes and gave it some gas while in park and the first 2 or 3 times it was fine, but the next time it died out. I was able to start it again unassisted and tried to give it some gas again and it died out again. I decided that I was just happy that it ran so we called it a day. After about another half hour I tried to start it again and it wouldn't start. I went back earlier today to have my buddy jump it again and I was going to let it run for a half hour or so but it went back to making the attempt to start but wouldn't turn over, even with the jumpers connected to his running Explorer. Any ideas as to what's the issue?
I'm most likely going to have it towed to a shop next paycheck and get these issues fixed. I need this thing running before the snow really fly's.
Old Nov 11, 2014 | 03:33 PM
Does anything at all happen when you turn the key to start? Might try swapping the starter relay, and the horn relay. See if that helps.
Old Nov 11, 2014 | 04:33 PM
BenB010's Avatar
BenB010
It just cranks and cranks but won't fire.
Old Nov 11, 2014 | 04:38 PM
What's missing? Spark, or Fuel?
