P0031 & P0037 Code, need help please
Old Mar 28, 2020 | 01:32 PM
Bosch..... Yeah. These trucks simply do not like the bosch sensors. NTK or Denso only. Any other just cause more problems than you are trying to solve.
Old Mar 28, 2020 | 01:56 PM
Tony G's Avatar
Tony G
ok, I will try the ntk sensor should I replace the upstream one also? About the heater should it only have 12 volts for a second right when ignition is turned on or should it stay on longer? Also forgot to mention that the short term fuel trim for downstream sensor says 99% and doesn't move dont know if that has anything to do with this or not. Thanks
Old Mar 28, 2020 | 03:13 PM
Yeah, replace 'em both. Heater circuit should see 12 volts for at least a few minutes.
Old Mar 28, 2020 | 03:26 PM
Tony G's Avatar
Tony G
ok, the auto shut down relay sends 12 volts for only a second when ignition is turned on with the sensor unplugged will it turn on longer with the sensor plugged in or is there a problem?
Old Mar 28, 2020 | 06:41 PM
ASD relay is only on for a few seconds at initial key on, after that, the PCM needs to see the engine turning it to leave it on.
Old Mar 29, 2020 | 01:51 AM
Tony G's Avatar
Tony G
ok, Thank you
