water in floor board
Old Oct 28, 2014 | 10:25 PM
devildog1187's Avatar
devildog1187
Default water in floor board
So in my 2001 1500 every time I turn the ac on it floods my passenger side floor board has this happen to any of you guys ??
Old Oct 28, 2014 | 10:57 PM
COL's Avatar
COL
Yes, My 1996 used to do this, it has something to do with a drain or vent or something in the heater core.
Old Oct 28, 2014 | 11:03 PM
Spillage's Avatar
Spillage
There are many threads on this... here is the most recent.
https://dodgeforum.com/forum/2nd-gen...somewhere.html
PS; Search is your friend.
Old Oct 28, 2014 | 11:29 PM
devildog1187
Thanks !!! I work offshore alot an don't really get alot of time to sit a Google an search every thing so that's why I joined here to ask ppl who own dodges this forum an the ppl in it have been very help glad I ran across this
Old Oct 29, 2014 | 02:19 PM
jmhd1989's Avatar
jmhd1989
if its coolant your heater core is bad if its water your drain is clogged. its right above the passenger control arm, a little hose tip. if you run ac but dont ever see water on the ground thats another sign it is clogged
Old Oct 29, 2014 | 06:19 PM
diverjer's Avatar
diverjer
If heater core, you would know as there would be antifreeze in water. On my 1996 the drain hole for A/C is below the dryer and can only be seen from under the truck. Small piece of black plastic sticks out from firewall, about half inch in length.
On some Fords I seen water come in on the floor after a rain, water is coming from the air intake that is cracked or broken.
Old Oct 29, 2014 | 07:11 PM
Spillage's Avatar
Spillage
I meant the Search on this site... when in the 2nd Gen forum, use Search this forum, and it weeds out a lot.
The thread I referred to was about 6 below your post, so a quick scan of the current thread listing would have done it without a search.
But I do understand the ease of just asking and letting other do the search, especially if you're tight on time.
Old Oct 30, 2014 | 11:01 AM
Ramman18's Avatar
Ramman18
Put some rubber tubing over the drain so that it drips down and away. Then add some sealant to the rubber bushing around the drain. Then pull up the carpet and start mopping.
