95 Dodge Ram 3500 no tach after 30 minutes
Old Oct 30, 2014 | 11:44 AM
bjr1a's Avatar
bjr1a
Default 95 Dodge Ram 3500 no tach after 30 minutes
Have a 95 Dodge Ram 5.9 Diesel, that after about 30 minutes of run time will lose Tach, Overdrive and the service engine light also ( after cooling,all will return)....The ESS has been changed.....Is there a definitive way of checking the PCM without replacing?....Thanks for any input..
Brian
Old Oct 30, 2014 | 03:23 PM
Get any codes?
Old Oct 31, 2014 | 12:24 AM
95' 360 Ram's Avatar
95' 360 Ram
Turn the key on then off 3 times before finally leaving it on count how may times the CEL flashes (i.e. 2 flashes then short pause is 2 and 3 flashes then long pause would be code 23)
Old Oct 31, 2014 | 09:57 AM
bjr1a's Avatar
bjr1a
In the Key ON/Off DTC retrievel mode, the code 35 is there, I get different meanings to the code, so I will attach a scan tool and see if there is more codes or perhaps a clear definition to that DTC...The only thing Alldata shows on DTC 35 is an ABS rear speed sensor code.......Perhaps that is correct, I am not sure righr now...
