96 dodge ram 1500 auto , transmission filter
Old 11-05-2014, 12:53 PM
jeremydodgen's Avatar
jeremydodgen
jeremydodgen is offline
Default 96 dodge ram 1500 auto , transmission filter
hey guys , just wondering whats the best filter for a automatic transmissoin. Also what transmission fluid should i use in it, atf 3 or atf 4? or is there a better one? trucks a 1996 dodge ram 1500 laramie, v8,318 5.2ltr magnum
Old 11-05-2014, 09:28 PM
HeyYou is online now
Dodge Forum Administrator
Received 3,200 Likes on 2,952 Posts
Use only ATF +4. Pick up a good quality filter, in a kit that comes with the rubber gasket.
Old 11-05-2014, 10:15 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
Felpro TOS18583 is a really really good rubber gasket, available from Advance. use the online discount codes.
Pro King FK-317 filter/gasket kit from Advance is also good. it's got the rubber gasket that doesn't leak.
but- make sure your pan lip is flat and tap down any dimples the stick up from previous over tightening.
the mopar gasket is very thick and supposed to be reusable. i kept mine but never reused it so i don't know for sure that it won't leak. mine seems a little hard.
Old 11-07-2014, 02:00 AM
jeremydodgen
hey guys , so whats the best engine oil i need ?
Old 11-07-2014, 02:10 AM
jeremydodgen
and also what oil filter should i use as well ?
Old 11-07-2014, 02:14 AM
jeremydodgen
also im going to be changing the spark plugs as well, whats the best one to replace it with ?
Old 11-07-2014, 07:52 AM
Stick with copper plugs. Our engines don't really care for the high-dollar, rare-earth plugs.
If you look in the faq/diy section, there are threads for what folks are using in various areas. Lots of good info there.
Since my truck has a pretty healthy appetite for oil, I just use whatever Advance has on sale at the moment.
Quick Reply: 96 dodge ram 1500 auto , transmission filter
