Small vibration?
Old Nov 9, 2014 | 03:29 PM
tazmaniac's Avatar
tazmaniac
I will check out the plugs although I did find a slip they where changed 8K miles ago but I am assuming the plugwire loom is original, might invest in both and hopefully going on the scanner in the AM..I found an old post with another driver with a dually had the exact same issue but lost the post lol
Old Nov 9, 2014 | 05:44 PM
djbucky3's Avatar
djbucky3
Its not a bad idea, IMO, to replace the parts of the ignition process. Plugs/wires/distributor/cap/injectors.. I like to know certain things are exactly as they should be.
Old Nov 9, 2014 | 07:45 PM
Ham Bone's Avatar
Ham Bone
Minus fuel injectors. I agree with this. Also those parts all together are right around 50 bucks so inexpensive.
Old Nov 9, 2014 | 07:50 PM
tazmaniac's Avatar
tazmaniac
I agree.. but been looking on-line quite a few choices for plugs and wires any suggestions will be appreciated but a distributor/cap ummm
Old Nov 9, 2014 | 07:51 PM
V-10, no cap or rotor.
Old Nov 11, 2014 | 12:51 PM
tazmaniac's Avatar
tazmaniac
Update
had it scanned no codes came up, even shut down each cylinder to check injectors all good, cleaned the IAT, cleaned the throttle plates and bore, checked most spark plugs they looked they came out of the box
It still has the very small vibration but I did notice one thing at least what it read on the Tach in the truck was 450rpm at idle but if i brought the idle alittle the vibration went away, I should of checked the actual rpm when plugged into the scanner I remember seeing a desired rpm of 738 but did check actual...possible issue??
Old Nov 11, 2014 | 03:28 PM
That sounds too low..... and may indeed be the issue. Wonder why the PCM isn't bringing it up some.....
Old Nov 13, 2014 | 05:42 PM
brink5's Avatar
brink5
450 does sound a bit low.
How's the condition of the battery.? My truck doesn't always start, idle, or high-idle right, when battery is getting weak. Worth checking at least.
Old Nov 13, 2014 | 08:29 PM
tazmaniac's Avatar
tazmaniac
PCM must have fixed it idles at 700+/- but still has the buzzing vibration...damn!
Old Nov 13, 2014 | 10:09 PM
Not just a loose heatshield somewhere is it?
