Old Aug 7, 2015, 03:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension
Print Wikipost
Rear Shock Mounting Bolt Replace
Old Nov 8, 2014 | 12:59 PM
johnrambo's Avatar
johnrambo
Default Rear Shock Mounting Bolt Replace
My bolt hold rear lower shock mount came out. Anyone know what size I need to replace it with and where I might possibly source one without paying dealer prices
Old Nov 8, 2014 | 01:08 PM
johnrambo's Avatar
johnrambo
Would this work?
LINK
Old Nov 8, 2014 | 03:07 PM
Think I would see what's left, bushings and such, then look at the other side, measure the bolt, and just pick one up at Lowes/Home Depot.
Old Nov 8, 2014 | 06:27 PM
armynurse's Avatar
armynurse
Junkyard. The ones I've been to usually have a lot of 2nd Gen trucks.
Old Nov 8, 2014 | 09:17 PM
Ram Driver's Avatar
Ram Driver
Take the bolt out of the other shock and go to the hardware store and match the size.
There is nothing special about the shock bolts. I would suggest grade eight bolts.
Old Nov 9, 2014 | 09:56 AM
Ham Bone's Avatar
Ham Bone
I would just get a grade 8 bolt, washer, and a nut.
Go home fix it and you probably spent more money on gas than parts.
Old Nov 9, 2014 | 01:45 PM
dhvaughan's Avatar
dhvaughan
^this. i had to replace one, it was about 9/16 or 14mm in diameter and 2-3 inches long. mine don't match, one is metric and one is SAE but it doesn't matter as long as you match the nut and bolt.
Old Nov 14, 2014 | 09:39 AM
MedicNathan's Avatar
MedicNathan
LMC truck has them. Expensive as hell, but they are they only place i've ever found the flag nuts
Old Nov 14, 2014 | 11:54 AM
merc225hp's Avatar
merc225hp
Some nut and bolt info, from the factory parts book.
06502817 LOCK NUT, M14-2.00, Shock Mounting, Lower (flag nut) Portland has 62 of them in stock and they cost $15.33 CDN
06502818 BOLT, Hex Flange Head, M14x2.00x80.00, Shock Mounting, Lower for front or rear shocks.
