Front driveshaft ?
Old Nov 8, 2014 | 01:58 PM
getdown78's Avatar
getdown78
Default Front driveshaft ?
My 96 R1500 ex cab has 5 in lift but is the front shaft in a bad angle with that much lift ?
Old Nov 8, 2014 | 03:05 PM
Measure it, and see. Keep in mind, the suspension moves. Jack up the front to basically unload the front suspension, measure your angles that way. See if anything is binding at full droop. If not, you are probably ok.
