need help. built a 318 but its tight cranking over wont start!
hey i got a question for all u motor people!
2001 dodge ram 1500 318 5.2 gas engine
so recently i built a motor i had the crank turned, bored .030" over, new comp cam, aluminum heads, everything is new. i went to crank it for the first time but its so ****ing tight it barley wants to turn over. keeps killing my battery's. i honestly think its a starter or the wrong barring around the crank, (too tight). what do u think? before i pull it apart and measure the difference by plastagauge or micrometer and bore indicator
my reasoning on being too tight: the piston to cylinder wall clearance is with-in spec. however the guy who machined my crank could of not gave me the right barrings because its too tight around the crank. is this normal? the guy said sometimes it takes 3-4 trys on new motors. let me know what u guys think its brand new 0 hours 0 miles.
Agreed! The machine shop where I live won't bore the cylinders out till they get the new pistons because they want to make sure it's right. I know that on the last engine I built, I was able to turn the crank in the short bock without issue.
the machine shop turned my crank, got me pistons and rings, also supplied the barrings. could it be my starter? or is it a barring. i dont want to spin a barring id rather measure i just didn't measure during assembly cos i thought the machine shop did it for me since they supplied me with the parts. piston to valve clearance is good. ima just pull it measure it and start from there. thanks
Trending Topics
**** no not even close to being right, he cut the crank he should be able to have cut it so the bearing's have the right clearance. If the bearings are that tight and it does run up you will **** the crank and the bearings. Are the bearing caps installed in the right orientation?????
IF he turned the crank it was either .05 or .10 under most likely. Then all you do is get a set of bearings that are made for a crank that is turned under that much. But you always check your clearances when you're putting the engine together. That is why you have to plasti-gauge the clearance.
Good luck tomorrow.
Good luck tomorrow.
