A/C compressor kicking on and off with heat on
Old Nov 19, 2014 | 02:34 PM
gertie240's Avatar
gertie240
Default A/C compressor kicking on and off with heat on
Point me towards the right direction, It finally got cold enough here in south Texas to need the heater. With the heater on in any position I can hear my compressor kicking in and out. Is this normal operation? Maybe a faulty selector switch? What do you guys think. All opinions will be considered, some will be tried. Thanks
Old Nov 19, 2014 | 02:54 PM
I know on my 2014 Journey, the compressor comes on and off on it's own to control cabin humidity regardless of selector switch setting. I was thinking this was a featureon newer vehicles where more and more stuff is computer controlled. Not so sure this would be the case on a second gen Ram.
Old Nov 19, 2014 | 03:43 PM
I think the only setting it WON'T cycle in, is Heat.
Old Nov 19, 2014 | 04:11 PM
gertie240's Avatar
gertie240
So far I am looking at either pulling the fuse and not having a good defroster or breaking out the FSM and tracing the circuit. Maybe that is what took out my original clutch coil.
Everbody knows us lazy people just want someone to give us the answer. Wait, nobody said plenum or clogged cat. LOL
Old Nov 19, 2014 | 08:36 PM
The purpose of running the compressor when for the defroster is: (ostensibly) Refrigerated air carries less moisture....... so far as I am concerned, if I need the defroster, all the air outside is ALREADY pretty 'refrigerated'...... but then, I am in michigan, and you are in Texas.......
Old Nov 19, 2014 | 09:13 PM
COL's Avatar
COL
Its normal. Nearly all of the dodges do it. Simple solution, unplug the wire connector going to the A/C compressor. Ive done it with no harm to any of mine and you don't have to listen to the annoying compressor kick on and off.
Old Nov 20, 2014 | 07:35 PM
UnregisteredUser's Avatar
UnregisteredUser
But you might have to replace your compressor when the long months of not running the thing cause it to self destruct the next time the clutch is engaged.
Old Nov 20, 2014 | 09:09 PM
dean98ram1500's Avatar
dean98ram1500
I can second this. I have noticed with the heat on, vents coming straight at me, the compressor doesn't run. As soon as I flick it to the feet/coming straight at me selection, I can hear my compressor kicking on and of intermittently. Quite annoying if I may say so myself as I don't want to burn the dam thing out.
Now, may I also point out, I'm a candidate of the "wacky vents". (can't find that dam vaccuum leak, and also do not have the system full of refrigerant as it keeps leaking out of the dam system. lol. Oh the joys of owning a Dodge!
Old Nov 20, 2014 | 11:30 PM
ReadRam's Avatar
ReadRam
I think it's the plenum! Har Har! Compressor is designed to come on in defroster mode, not only for the moisture thing, but to keep the seals from drying out. As most people wouldn't turn it on until next summer, so it;s a default thing. If it's kicking on and off a lot for short time, then maybe low refrigerant.
Old Nov 21, 2014 | 01:27 AM
COL's Avatar
COL
i have done it for years on all my trucks and NEVER had a A/C compressor problem.just unplug it and be done with the annoying thing. Plug it back in when the weather turns warm again.
