1996 1500 4WD Transfer Case
Old Nov 20, 2014 | 08:58 AM
alwood85's Avatar
alwood85
Default 1996 1500 4WD Transfer Case
I have a 96' 1500 4WD, and the transfer case went out. The case did not have the tag on it, so I assumed it was a NP231. I got a used tcase from a guy for $100, but it also did not have a tag. He told me that it would fit a 94-97 Ram.
I got the tcase bolted on, but the front shaft could not be bolted on. The tcase had a U-joint. My local salvage yard said this is a rare tcase, and I now required a front shaft with U-Joints on both ends.
Anyone run into this problem? Any recommendations to resolve my t-case/front shaft issue?
Thanks.
Old Nov 20, 2014 | 02:57 PM
Take the flange off your old case, put it on the new case, use your original front driveshaft.
