Hard to Steer
Old Feb 10, 2015 | 10:06 PM
It's a pump. Output is tied directly to engine RPM. The faster the engine goes, the more hydraulic pressure you can get.
What makes me suspect the pump is: bumping RPM a bit makes it start working. So, either a bad flow control valve, or, simply the wrong one. (I don't think they are replaceable separately.... gotta get the whole pump.)
Old Feb 10, 2015 | 10:12 PM
issakar's Avatar
issakar
That's more what I meant. Normal operation there should still be power steering to some degree even at idle.
Old Feb 10, 2015 | 10:14 PM
I agree, even on my 3/4 ton truck, I can one-finger the steering lock to lock at idle.
Old Feb 10, 2015 | 11:42 PM
Ham Bone's Avatar
Ham Bone
Well I need a new pump then.
Old Feb 11, 2015 | 12:18 PM
Moparite's Avatar
Moparite
Was there any difference in the size of the pulley on it compared to the original? A bigger pulley will turn slower= low pressure. That's if you had enough slack in the belt for it to fit. Just thinking out loud.
Old Feb 11, 2015 | 06:25 PM
kgilhooley31's Avatar
kgilhooley31
Nope I actually had to put my own pulley onto it, and I think it was identical at least from just looking at it.. So either it was messed up out of the box..or wrong internals. Cause my pump was shot and made the terrible whine yet it still worked fine. This one has no whine yet doesn't even do anything. I'm sure its under warranty so I'll switch it, this time flushing very well too. However, I was looking into the mechanics/hydraulics to how the steering gear box works, and do you think its possible something in there all binding up with those worm gears and that cylinder? Maybe an internal leak? Cause I understand how rpms being raised would make the pump pump better, but what if the pump was pumping fine and then it was just the gear box all jacked up but then with the extra pressure it was able to overcome the shot gear box? Just my thoughts. Cause the gear box does leak slightly, but not pouring out fluid or anything. I hardly ever have to top the fluid off. It stays high, just a very slight leak.
Old Feb 11, 2015 | 06:34 PM
issakar's Avatar
issakar
I can't remember and I'm too lazy to re-read. Did you lift it up and turn the wheel looking for binding?
Before the change of the pump, did you have power steering? It was just noisy, right? I'd honestly start with the pump and go from there; don't stress yourself out on all the other possible issues yet. If you had power steering before the pump change, and now don't after the pump change, I'd tackle the pump first.
Old Feb 11, 2015 | 10:12 PM
kgilhooley31
Yes theres no binding when I had it up on a lift
Old Feb 11, 2015 | 11:09 PM
Ram Driver's Avatar
Ram Driver
While it is possible to get a new power steering pump that is bad, its also possible that the steering gear box on your truck might be going bad also. The steering gear boxes on these trucks arn`t known for being the best.
Old Feb 11, 2015 | 11:55 PM
kgilhooley31
Well, pump only took about an hour, and I just checked and the one I got from autozone is under a limited lifetime so I guess Ill start with that, won't cost me any money to put a new one in so ill do that. Is there anything I could of done in installing the old one that made something go wrong? All i did was pull lines off, undid pump and put new one in and put fluid in, turned wheels till it went down, refilled, then turned the engine on and kept fluid up while i went lock to lock. I didn't drain out the gear box, just let as much come out when i undid all the lines.
