misfire
Old Nov 24, 2014 | 08:42 AM
michael2788's Avatar
michael2788
Default misfire
i have a 96 dodge 1500 with 5.9 i had code po300 and po301-308 changed all spark plugs and wires still skipping
Old Nov 24, 2014 | 09:02 AM
Ram Driver's Avatar
Ram Driver
Check the crank shaft position sensor, when they start going bad they can cause a miss fire. If its the original sensor with lots of miles on it, it would be a good idea to replace it.
Old Nov 24, 2014 | 02:48 PM
Have a look at your plug wires, dist cap, and rotor as well.
Old Nov 25, 2014 | 08:27 AM
michael2788
i did the dist and roter button still all 8 misfire.. i just bought the truck it has 196000 miles on it .Where is that crank shaft position sensor located?
Old Nov 25, 2014 | 09:06 AM
Ram Driver's Avatar
Ram Driver
Its on the right side of the engine by the exhaust manifold, sticking through the back of the engine toward the flywheel.
Old Nov 25, 2014 | 04:56 PM
Pain in the keester to see it, let alone change it.....
Unplug your front O2 sensor, and see if the misfire goes away.
Old Nov 25, 2014 | 07:04 PM
Spillage's Avatar
Spillage
I'd +1 on this... I had a random misfire issue that start at ~150k... nothing major, just the occasional annoyance... it became more prevalent, and I finally changed it at ~175k... bingo, problem solved.
Any sensor with more than 100k on it should be changed, in my book.
