idle issue....
Old Nov 30, 2014 | 10:40 PM
Yep, entirely possible. If it hasn't been addressed yet, good chance that it is at least part of the problem.
Old Dec 13, 2014 | 12:34 PM
Vanreed01's Avatar
Vanreed01
Ok so I pulled the intake and re did the plenum gasket and the intake gaskets to make sure that wasn't my problem and it still dose the same ****
Old Dec 13, 2014 | 12:49 PM
Does it start doing it immediately at startup? Or, does it take about two minutes for it to start misbehaving?
Old Dec 14, 2014 | 11:33 AM
Vanreed01's Avatar
Vanreed01
It's fine on a cold start..takes about 5 minutes until it starts acting up
Old Dec 14, 2014 | 11:35 AM
How old are your O2 sensors? If they are new, what brand?
Old Dec 14, 2014 | 12:46 PM
Vanreed01's Avatar
Vanreed01
The upper is brand new it's bosh o.e. replacement. .the lower is original from 1996
Old Dec 14, 2014 | 01:37 PM
Spillage's Avatar
Spillage
Originally Posted by Vanreed01
....it's bosh o.e. replacement...
There's one problem... they don't like Bosch sensors... get an NGK O2 sensor.
Old Dec 14, 2014 | 01:48 PM
onegoodmason's Avatar
onegoodmason
Just unplug the upstream sensor . You will get a CEL for it but the PCM will run on preset perimeters and should run just fine , if the sensor is an issue . Bosch is certainly hit and miss with OBDII magnum engines .
Old Dec 14, 2014 | 11:08 PM
Vanreed01's Avatar
Vanreed01
Ok cool thinks I will check that out on Friday when I am off work..any other suggestions in the mean time please let me know. Thanks again guys
Old Dec 18, 2014 | 07:50 PM
Vanreed01's Avatar
Vanreed01
Ok I replaced both the o2 sensors with ngk o2 sensors and it still dose the same ****
