heater blower quit working
Old Nov 30, 2014 | 10:12 PM
scotty088's Avatar
scotty088
Default heater blower quit working
My heater A/C blower quit working. I also now have a ABS and a Air bag check light on constant. I checked all fuses and relays, all ok. I'm at a loss as what to do next....Any ideas?
Old Nov 30, 2014 | 10:35 PM
Two fuse blocks, one on the drivers side of the dash, one under the hood, right behind the battery. Check fuses in both.
Are you getting power TO the blower motor? Switch provides ground path thru the resistor block to control speed.
What year is your truck?
Old Dec 1, 2014 | 11:05 AM
scotty088's Avatar
scotty088
94 Ram 1500. All fuses are ok. All blower speeds worked properly prior to this, not getting power to the blower motor. I'm stumped!
Old Dec 1, 2014 | 03:12 PM
Grab the 95 service manual from here. Wiring diagrams are in section 8W. have a look.
Old Dec 10, 2014 | 03:57 PM
scotty088's Avatar
scotty088
So, I traced my problem down to a bad ignition Sw. called local parts store got new switch. Very easy replacement, everything works properly except the key in switch buzzer works without the key in the ignition. It goes off when the door is closed. I can't seem to figure it out any ideas?
Old Dec 10, 2014 | 06:16 PM
Think that's a sensor (pair of contacts) in the ignition switch..... your lights weren't on, or something silly like that were they?
Old Dec 10, 2014 | 08:39 PM
ProjectTwinTurbo's Avatar
ProjectTwinTurbo
Sorry to change the subject. Haven't been on in a while due to the app crashing but now it won't let me post a new thread. But no longer doing the turbo idea. Heading a new direction. But I need help figuring out how much psi our ac units push. There's the sucnction side. And the other line that pushes(this one). If anyone has any idea. Or a estimate. Would be greatly appreciated. Also if someone could put this in a thread. Thank you!
Old Dec 11, 2014 | 10:56 AM
scotty088's Avatar
scotty088
Everything works properly except the key buzzer is on with the door open and no key in switch. I called the Auto parts store where I purchased the switch. They contacted the switch mfg. who thinks it is a defective switch. They ordered a new switch, We will see what happens. I'll keep you updated
