auto to manual?
Old Dec 7, 2014 | 03:38 PM
Ham Bone's Avatar
Ham Bone
Dodge Order code was DDC
http://www.allpar.com/mopar/transmissions/NV3500.html
Old Dec 9, 2014 | 06:09 PM
Timothy Watrous's Avatar
Timothy Watrous
did the fly wheels also changed for the 5.9 in 96-97?
Old Dec 9, 2014 | 06:18 PM
Timothy Watrous
i found two flywheels from summit ones listed that it will fit 97 - 02 magnum 360s. and another listed to fit 71-92 la block 360 and 92 magnum 360s... so which flywheel fits a 93-96 magnum 360?
Old Dec 9, 2014 | 09:22 PM
I *think* 93-95... or so.... had the balance weights on the torque converter..... if you have a manual trans, I would call your favorite place to order parts from, and have a chat.
Old Dec 11, 2014 | 08:25 PM
Timothy Watrous
heyyou where talking bout flywheels. not flex-plates although the toque converter i just took out has balance weights on it... the dodge parts manual gives the same part number for 94 and 98 years... part # 50-2754 should work.
Old Dec 12, 2014 | 07:33 AM
That seems reasonable, can't see them putting weights on the pressure plate.
Old Feb 17, 2015 | 12:44 AM
Timothy Watrous
well finished my swap and put about 300 miles on it so far... but now i got codes popping up... 12,45,37,37,21...
12 isnt an issue.
21 i know what needs to be fixed
45 and 37s is overdrive solenoid and trans temp, is there any way to trick the pcm on theas codes?
details on swap... 94 5.9 magnum. np435, homemade adapter to a np231
Old Feb 17, 2015 | 09:31 AM
Does your truck even have the trans temp sensor? If it does, it would be on the forwardmost trans line, close to the trans. Check and see if it's there, if it is, is it plugged in?
Old Feb 17, 2015 | 10:23 AM
Scooter78's Avatar
Scooter78
If Im following you correctly, you ditched your auto for a standard. I did the same thing. Your pcm will throw trans temp, shift solenoid codes for the rest of time, unless you change pcm or have yours flashed to a standard trans pcm. It will not alter performance in any way, and will have no adverse effects. Also, earlier you asked if the 96 and older flywheel was different than the 97 and newer. The answer I believe is yes, and I understand it is because of the crank position sensor's interaction with it. The crank pos sensor changed from the obd1 and obd2 trucks (1997). Weather or not one generation will function properly with the other, I do not know.
Old Feb 17, 2015 | 12:02 PM
Timothy Watrous
hey you. yes it had the temp sensor in it... it also had factory lines without the check ball in it....
scooter. i droped a np435 in and the 97and newer flywheel works i just shimmed my crank sensor...
now the overdrive and temp codes... wile doing the swap. i noticed the wire harness had the plug for the clutch pedal sensor... it just had a plug with a wire looped back... now in theory i should be able to use a similar trick for the overdrive... being that i have an overdrive off switch... ?
for the temp sensor i guess i could just plug it in or make a port for it in the np435...?
