auto to manual?
1st of all computers don't have feelings.
2nd the "tcc" code, code 37** says torque converter clutch (tcc) solenoid circuit open or shorted.... which implies that the code comes on when there's ether a short or break in the circuit... so running a wire connecting the circuit would turn code off.
3rd if the pcm expects an rpm drop, ether tell me what code would pop up and how. or post up a programming diagram for the pcm, because i don't know were your getting your information from
YOU NEED TO REPLACE YOUR PCM!
Why cant you seen to understand that? You can't just fool it into not trowing codes. It monitors all the inputs and if something is not within the correct parameters or sequence it will throw a code plain and simple.
2. Correct.
3. Looking at your sig, you have a 94, thus, you are indeed correct. I am unsure if that will set a code outside the two conditions stated. (the OBDII fellers have a code for it.....)
