speedo dont work until i hit 30mph
Old Dec 11, 2014 | 04:28 PM
$A_Money$'s Avatar
$A_Money$
Default speedo dont work until i hit 30mph
hello I have a 99 ram 318 5speed when I got the truck the speedo didn't work....I got underneath an found out that the abs wires goin into the rear end was cut...so I spliced em back together an now it starts to work after I hit bout 30 or so....is it the speed sensor on the tranny or wut?
Old Dec 11, 2014 | 05:15 PM
Check your splices to make sure they are good. If they are, replace the sensor.
Old Dec 11, 2014 | 07:01 PM
$A_Money$'s Avatar
$A_Money$
I'm pretty sure the splice is good so the sensor is bad? Unless there is another break in the wires to the abs?
Old Dec 12, 2014 | 07:38 AM
Nah, that is fairly standard behavior for a failing sensor. Cheap and easy to replace as well.
Old Dec 12, 2014 | 10:30 AM
Sheriff420's Avatar
Sheriff420
When I had a bad rear wheel speed sensor (on top of the rear differential) the abs and brake light were on and the speedometer didn't work until I hit about 30mph.
Old Dec 12, 2014 | 02:25 PM
$A_Money$'s Avatar
$A_Money$
Yea mine wasn't workin at all until I spliced the wires goin to the sensor on top of the rear end now it starts workin at bout 30
