Weird headlight problem
Old Dec 11, 2014 | 08:12 PM
jsmith1969's Avatar
jsmith1969
Default Weird headlight problem
I just got a 99 Dodge 4x4 Sport as a new toy to build up and have my first head-scratcher already. Only the inner high beams and the passenger low beam were working. So this evening after work I stop and get a bulb(9007) and both low beams work but when I flip to highbeam just the outer bulbs switch to high now and I get nothing the inner. Anyone got any ideas?
Old Dec 12, 2014 | 07:36 AM
My sport only has two bulbs total.... so, I may ask some silly questions here....
Thought they used 9004 bulb?
Are all four supposed to be on with the highbeams? Don't have the connectors mixed up do you?
Old Dec 12, 2014 | 08:58 AM
jsmith1969's Avatar
jsmith1969
I replaced it going off the burnt out bulb, I did check the other side and it's a 9007 too. The inner bulbs are 9004 though.
I don't think so, maybe I worded my problem wrong. At first before I replaced the bulb the outer bulbs(actually only the one since the drivers side was burnt out)were one in low and when I flipped to high beams the outer went off and the inner were on. Now after replacing bulb the outer are on for low and when I flip to high beam the outer bulbs light up in high mode now and the inner don't light up at all.
No I put it back exactly as it was, though now that you say that I wonder if the original owner had them mixed up at one time.
Soon as I'm off work will check the connectors are on right, is there a way to tell by looking or will I need to swap them around to test them?
Old Dec 12, 2014 | 09:00 AM
Look at them and see if they are different.
Old Dec 13, 2014 | 02:12 PM
jsmith1969's Avatar
jsmith1969
Ok problem is fixed. I went up to NAPA and the counter guy suggested trying 9004 in all of them and it's working now.
