Coolant Temp Sensor
Old Dec 18, 2014 | 08:14 PM
elmoe's Avatar
elmoe
Default Coolant Temp Sensor
I have a Jeep TJ with a 5.9 engine and recently installed an electric fan. I'm in need of a way/adapter that would allow me to run two temp sensors from the original location next to the thermostat housing. Does any one have any ideas? I currently have an adapter in the top radiator hose but I cant get my fan's controller to match the actual temp of the engine. Thanks for any help.
Old Dec 18, 2014 | 10:10 PM
Drill and tap the boss for the second sensor found on the older manifolds (pre-98), and install it in the manifold. Should be just to the drivers side of the thermostat housing.
Old Dec 19, 2014 | 01:29 PM
merc225hp's Avatar
merc225hp
This might help
Old Dec 20, 2014 | 10:30 AM
elmoe's Avatar
elmoe
Thanks guys!!!! Mine is a 98 so I'm not sure if I have the second port. I will check later and see.
Old Dec 20, 2014 | 12:09 PM
merc225hp's Avatar
merc225hp
98 won't thats why HeyYou said to drill and tap, the pix gives you an idea where to drill and tap for the other sensor.
