Truck choking out at idle
Old Dec 21, 2014 | 02:15 PM
Mygoldn's Avatar
Mygoldn
I took a vid but I don't know how to post it from my ipad
Old Dec 21, 2014 | 02:16 PM
Mygoldn's Avatar
Mygoldn
Originally Posted by onegoodmason
Check your TPS .
How do I check the tps. Sorry. This stuff is kinda new to me for checking them out
Old Dec 21, 2014 | 02:59 PM
onegoodmason's Avatar
onegoodmason
With a multimeter , ignition to on engine off , probe the middle with with the positive , ground off the negative . Ideal reading is 0.44 volts . You want it between the .4-.7 range . Higher does give better throttle response off the line . (can be tweeked) In your case , if I'm right , you will have low readings here . To further test the TPS , cycle it through the range to WOT while watching the meter . It should climb to an ideal 4.5 IIRC , or close to .
Hope this helps
Old Dec 21, 2014 | 03:26 PM
Both front bolt holes go all the way thru, and are outside the motor. If you don't have anything in there, some bolts and nuts will work just fine.
Old Dec 21, 2014 | 11:57 PM
Mygoldn's Avatar
Mygoldn
Ok. Sounds good. That's what I figured. I just gotta get back in there to do it : ). I always seem to pick the coldest time of year to do work so that might have to wait till spring.
Old Dec 21, 2014 | 11:58 PM
Mygoldn's Avatar
Mygoldn
Hope this helps
Il I've that a try tomorrow thanks!
