Rebuild help
Old Dec 22, 2014 | 05:12 PM
98Case-N-Ram's Avatar
98Case-N-Ram
Default Rebuild help
I rebuilt my magnum 360, upon my attempt to start the fresh rebuild it would start at WOT go up to 500rpm and die, starting fluid does not work, I have replaced my bad fuel pump, and am stumped, cam sensor is non-Mopar which was replaced when the engine first quit, so it is unknown if it is faulty, I tried a non-Mopar crank sensor and it did not do its job. Any insight would be appreciated.TIA
Old Dec 22, 2014 | 10:27 PM
Welcome to df!
Check and make sure you have your engine coolant temp sensor plugged in. If your truck is 97 or older, you will have two. One is a one wire, the other is a two-wire. Need to make sure you have the right connector on the right sensor, else the PCM thinks it is -40, and will DUMP gas. That'll wash out cylinders, and trash your oil in short order. Pull the dipstick, and take a whiff, smell like gas?
Old Dec 23, 2014 | 04:18 AM
98Case-N-Ram
The sensor is plugged in if I recall, I used a watchdog to monitor coolant and whatnot when I tried starting it and I dont remember it reading -40, after sitting for 4 months at the stealer ship so they could figure it out, they claimed it "feels too tight" so they wont crank it, will an aftermarket cam cause a problem, my cam is hughes engines HUG HER0814AL.
Old Dec 23, 2014 | 08:35 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
What about your timing? I own one of those camshafts (not using it), but when I installed it, my crank gear for my timing set had 2 dots, and I aligned my timing to the wrong dot... After adjusting the distributor and getting it way off of where it should be, the truck started, but ran like a dog (obviously). The way it ran, kind of matches the description of how yours is running. Are you sure your Crankshaft and Camshaft are properly aligned?
Old Dec 23, 2014 | 10:39 AM
98Case-N-Ram
The timing marks were lined up, we roated the distributor and it didnt do much.
