Oil consumption ideas?
Old Dec 26, 2014 | 09:42 PM
rdharper02's Avatar
rdharper02
Default Oil consumption ideas?
So my 2000 mile motor came up about a quart and a half low the other day. It had passed California smog after the 500 mile brake in, but seems to be burning some oil. After checking the plenum (its clean) I started pulling plugs. Cylinder 2 and 8 both showed signs of burning oil. So today I ran down the valve stem seals for my almost new aftermarket heads. I did find the number 2 cylinder had a seal I could pull off by hand. So after replacing the seals on that side, she still appears to be burning some oil as I pull the throttle. Any ideas?
Old Dec 26, 2014 | 10:21 PM
Who built the motor? Could be any number of things, from poor ring sealing, to having the ring gaps in the wrong spots.....
Old Dec 26, 2014 | 10:43 PM
rdharper02's Avatar
rdharper02
HY, I had a local builder here in Southern California go back through the engine. BAR Machining. The guy that runs it has a pretty good reputation on Magnum motors, so I'm hoping that I have missed something small. If I get a chance tomorrow, I am going to pull the plugs again and do a compression test. Time has been the hardest thing to come by at this oint.
Old Dec 27, 2014 | 11:59 AM
You could also try the PCV valve, but, since you aren't seeing much in the intake, that may or may not help.....
