stand alone efi system
Old Dec 31, 2014 | 01:26 PM
heminutt's Avatar
heminutt
Default stand alone efi system
I have a 99 ram I wount to put a stand alone efi system on it cause I am building the motor will the stock gauge cluster work
Old Dec 31, 2014 | 01:38 PM
onegoodmason's Avatar
onegoodmason
All I can foresee are a lot of complications .
Better idea ;
performance intake
bigger throttle body
bigger 4 port injectors
tuner
Old Dec 31, 2014 | 01:55 PM
merc225hp's Avatar
merc225hp
Op that depends on the type of stand alone system you get and how you wire all this in. Very good chance your stock dash will work just fine.
@ onegoodmasion stock injectors are good to 450hp no need to change them out for a bigger set.
Old Dec 31, 2014 | 02:02 PM
onegoodmason
four hole vs 1 hole provides better atomization of the fuel . Stock motor I would not worry about it , but , if building , they are better .
Old Dec 31, 2014 | 02:04 PM
onegoodmason
Oh yeah , why downgrade from 8 to 2 injectors anyways . EFI is so late 80 , early 90's technology . MPFI is better
Old Dec 31, 2014 | 02:57 PM
merc225hp's Avatar
merc225hp
I went from a single hole stock injector to a three hole injector, not one bit of difference in fuel trim or performance was noted (and she ain't stock). Fuel trim can be adjusted if a tuner is used, there is no need or gain to going to a three or four hole injector on these motors.
I don't use a tuner so this is why I went up in one injector size as I had a mid range lean spot.
Old Jan 1, 2015 | 11:29 AM
Adobedude's Avatar
Adobedude
If it's an auto, you'll loose the auto shift and the stock gauges on these things are all but worthless except the speedo, first thing you should with a built motor is make sure the gauges are accurate.
Why the standalone EFI, people are having good luck with SCT tuners now with some serious motor builds.
Old Jan 1, 2015 | 04:01 PM
heminutt's Avatar
heminutt
Ok thanks I mite just go with a sct. I am also looking at what I will all need to make a 350hp 360
Old Jan 2, 2015 | 10:19 PM
AtomicDog's Avatar
AtomicDog
Build the 5.9 into a 408 stroker, add in good set of heads, intake and mild camshaft and you will be well on your way to that horsepower goal.
