Transfer case leaking with new OEM gasket PHOTOS ADDED
I re sealed my transfer case, not leaking from the case halves, and installed new Mopar metal gasket between case and extension housing bell part and new seal on extension housing where the drive shaft inserts. Problem: its not leaking or weaping i would call it more like sweating, beyond minimal, but its still ticks me off. its a brand new gasket from Dodge, is this common? should i have used rtv or a different brand? 231 T-case
in the manual it says to put mopar silicone sealer on the threads. Is that RTv? i searched for it and only mopar rtv shows up so i assume its the same. never used rtv on threads before is the only thing
