Engine question
Old Jan 8, 2015 | 04:10 PM
$A_Money$'s Avatar
$A_Money$
Default Engine question
I have a 99 dodge ram 318 5speed I was wondering if a 360 out of another truck would bolt up to my trans?
Old Jan 8, 2015 | 04:45 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Yes you can bolt a 360 to your tranny. Now here are the BUT's
1) You will need the 360"s flex plate as the 360 is externally balanced and the 318 is internally balanced
2) You want to use a 96 or newer engine. You'll need the 360 PCM or get your PCM reflashed.
3) Depending on year injectors may take different plug. Both engines use same injector so you can swap.
Try doing a search on engine swaps. There are tons of threads about the subject. Also it helps if you put your truck info in your profile as it makes it easier for us to help you.
Old Jan 8, 2015 | 05:12 PM
UnregisteredUser's Avatar
UnregisteredUser
Flex plate in front of a manual transmission?
Old Jan 8, 2015 | 06:00 PM
$A_Money$'s Avatar
$A_Money$
Ok just makin sure my 318 is startin to make noise an my buddy has a 360 out of a dodge ram I don't remember wut yr but it ran an I was just curious wut it would take to do the swap didn't kno if my flywheel would work an injection system would work or my trans but it sounds like it should?
Old Jan 8, 2015 | 06:18 PM
Your flywheel won't work, you need one for a 360. Also, if the 360 came from an auto trans truck, you will need a pilot bushing (or bearing, not sure which dodge used there.)
Old Jan 8, 2015 | 06:27 PM
$A_Money$'s Avatar
$A_Money$
So a flywheel an pilot bearing an computer? Then it should work?
Old Jan 8, 2015 | 06:40 PM
Yep that's it.
Old Jan 8, 2015 | 08:43 PM
$A_Money$'s Avatar
$A_Money$
Ok good if it's that easy why didn't Chrysler put the 360 with a 5speed in a 1500 from the factory?
Old Jan 8, 2015 | 09:29 PM
because the NV3500 wouldn't last 50K miles behind the 360, and the 4500 weighed too much.
Old Jan 8, 2015 | 09:49 PM
$A_Money$'s Avatar
$A_Money$
Is that what is in my a nv 3500? My truck it has rebuilt trans an now my motor has started a knock I do believe in the bottom end.... I can get my hands on a 96 360 with the computer.... Wut kind of flywheel do I buy? The 360 Has everything beside the harmonic balancer....so I'd need a balancer an wutelse?
