Truck dies when i put it in gear!!!
Old Jan 16, 2015 | 11:21 AM
Ace8929's Avatar
Ace8929
it also dies when i put it in drive, it will start back up if i press the accelerator all the way to the floor. could a clogged cooling system(-heater core-radiator- bad thermostat)? And dude, i changed the crank sensor, didn't do anything
Old Jan 16, 2015 | 12:08 PM
Cooling system won't have anything to do with, unless the problem only shows up when the engine is over-heated......
have you cleaned the throttle body? Replace the IAC motor?
