2000 Dodge 1500 hvac vacuum leak
Old Jan 9, 2015 | 12:42 PM
riversidefirewood@gmail.com's Avatar
Default 2000 Dodge 1500 hvac vacuum leak
I'm having problems with my air switching from the dash to defrost I tracked down a missing vacuum hose that I think is the problem its on the tee where the check valve is but it's not the check valve itself if any one can help it would be greatly appreciated I'll try to post a pic if I can figure out how
Old Jan 9, 2015 | 12:47 PM
Wild vents. Standard with these trucks. Any vacuum leak will give you the symptoms.
Welcome to DF!
Old Jan 9, 2015 | 12:52 PM
This is the hose that's missing
Attached Thumbnails 2000 Dodge 1500 hvac vacuum leak-img_20150109_124425380.jpg
Old Jan 9, 2015 | 12:58 PM
2 or 4 wheel drive? If 4, does it work?
Old Jan 9, 2015 | 01:17 PM
4wheel drive and it does work
Old Jan 9, 2015 | 02:34 PM
armynurse's Avatar
armynurse
I had this problem once, and it was a vacuum line for the cruise control. It's hidden under the battery tray. Take a look there if after you find your missing vacuum it still doesn't work.
Old Jan 9, 2015 | 04:34 PM
I think my problem is I'm missing a vacuum hose which you can see in the pic I posted I can't seem to find the missing hose or where its supposed to run to
Old Jan 9, 2015 | 06:20 PM
UnregisteredUser's Avatar
UnregisteredUser
The missing hose connects to a tee that's in another vacuum line that runs right along the valley formed between the intake manifold and valve cover.
Below the throttle body on the passenger side of the manifold there's an elbow connected to a vacuum port, with the outlet turned rearward. A couple or three inches back there's a Y connector, and a few inches behind that in the run that goes straight back toward the firewall there's the T where that missing hose connects. That T is approximately in the plane of the back of the intake manifold, and probably partially obscured by another hose or two.
