5.9 magnum misfires after new tranny
Old Jan 13, 2015 | 09:42 PM
97ram360ci's Avatar
97ram360ci
Default 5.9 magnum misfires after new tranny
Hey guys I put a new tranny in my truck it's a 1997 ram 1500 with 173k and after I put it in it's now throwing a code for cylinders 3,4,5,6 misfires and I really haven't looked into yet I'm taking the cap off tomorrow and looking at the points and the rotor but I heard a thing if you don't have enough fuel and if your fuel filter is clogged it'll cause misfires and I also heard if your plenum gasket is bad it'll cause misfires but I just wanted to get some advice any advice will help thanks fellas
Old Jan 13, 2015 | 10:14 PM
AtomicDog's Avatar
AtomicDog
I'm assuming this is an automatic transmission, correct? Did you remove and install the new transmission yourself? Was the motor running bad before you removed the old transmission? What code is it throwing?
Old Jan 13, 2015 | 10:52 PM
UnregisteredUser's Avatar
UnregisteredUser
No you're not. There are no points to look at.
Almost every time someone says that a transmission R&R was followed by misfires it's because the crank position sensor got banged up.
Old Jan 14, 2015 | 06:23 AM
97ram360ci's Avatar
97ram360ci
I forget the code number and yep I completely forgot about the crankshaft sensor but wouldn't throw a code for the crankshaft sensor and yes I replaced it myself
Old Jan 14, 2015 | 08:09 AM
AtomicDog's Avatar
AtomicDog
For this forum to really help you, you need to be able to provide us with details of your issue, such as the code being thrown and the specifics of your truck. When you have a moment, please update your profile to include information about your truck, such as 2WD VS. 4WD, auto vs manual trans, etc.
I asked if you installed the transmission or not, as the crank sensor is the most likely culprit of your issues, as its very easy for it to get damaged unless care is taken with the sensor during the removal/installation process.
Old Jan 14, 2015 | 08:30 AM
97ram360ci's Avatar
97ram360ci
The codes were p0303 p0304 p0305 p0305 and it's a 1997 ram 1500 with a 5.2 sorry I said 5.9 earlier my last one had a 5.9 but it's an automatic and I replaced the tranny my self and I just took out the crankshaft sensor and it doesn't l
97ram360ci's Avatar
97ram360ci
The codes were p0303 p0304 p0305 p0305 and it's a 1997 ram 1500 with a 5.2 sorry I said 5.9 earlier my last one had a 5.9 but it's an automatic and I replaced the tranny my self and I just took out the crankshaft sensor and it doesn't look damaged it's just covered in oil and I'm not sure if that suppose to be like that or not
Old Jan 14, 2015 | 10:52 AM
No, it shouldn't be covered in oil....... When you had the trans out, was there oil behind the flexplate?
is the bracket for the crank sensor bent at all? This particular scenario is awfully common.... change the trans, engine either won't run, or runs bad..... 99% of the time its because the crank sensor got tweaked. Or, a wire harness got pinched.
Old Jan 15, 2015 | 06:43 AM
97ram360ci's Avatar
97ram360ci
I got it for hired out I put my old trucks cat on there and I guess it was clogged so I took it off and it ran fine so I put the the stock cat back on it and it's running great now
