RWAL - is this normal operation?
Old Jan 15, 2015 | 03:21 AM
jf1000's Avatar
jf1000
Default RWAL - is this normal operation?
Hi,
I have a 1998 1500 4x4 with rwal (no front abs just rear). In the 17 years I've owned this truck I've never noticed the rwal kicking in. Last week I had the rear drums turned to eliminate shuddering during heavy braking. I was doing some high speed stops to make sure the shuddering is gone (it is) and noticed what I think is the rwal kicking in. Basically mid stop it feels like the rear brakes stop engaging and the fronts are providing all the stopping power. On my wife's car with front abs you can feel the brakes going on/off, On my ram you can feel the rears brakes turn off but they don't seem to turn on again. This causes the stopping distance to be considerably greater than prior to turning the drums. My thought is the finish left from turning the drums is causing the rears to lock up much easier. Does this sound like normal rwal operation?
Thanks, Jim
Sent from my iPad
Old Jan 15, 2015 | 06:24 AM
UnregisteredUser's Avatar
UnregisteredUser
That doesn't sound normal to me, and the result of turning the rear drums should not in any case be reduced stopping power.
Old Jan 15, 2015 | 09:35 AM
The RWAL on these trucks is pretty useless anyway......
Old Jan 15, 2015 | 09:41 AM
jf1000's Avatar
jf1000
Default Is it noticeable when it kicks in?
Is there click noise or something that lets you know Rwal is operating?
Old Jan 15, 2015 | 10:25 AM
Probably, but, whether you can hear it or not is open to debate. All the RWAL is is a dump valve on the rear brake line. I am not even entirely sure how it decides to engage.... The only clue it has how fast things are going is from the VSS, or rear wheel speed sensor...... Maybe it looks at how quickly speed changes.... who knows.
Old Jan 15, 2015 | 02:01 PM
Ham Bone's Avatar
Ham Bone
Its working correctly if you slam it on slippery surfaces and you feel the brake pedal pulsing. Almost like it's trying to push up into the not braking position.
Old Jan 15, 2015 | 06:55 PM
The 4WAL guys will do that, but, the RWAL guys don't. RWAL just bleeds off some pressure to the rear brakes via the dump valve. 4WAL actually has a pump.....
Old Jan 15, 2015 | 07:42 PM
Ham Bone's Avatar
Ham Bone
Oh lol so it's useless in other words?
Old Jan 15, 2015 | 08:11 PM
Exactly.
Old Jan 15, 2015 | 11:17 PM
jf1000's Avatar
jf1000
I don't feel any pulsing just the rears stop braking. I'm hoping once the drums smooth out it will happens less.
