I've got all the wires fixed. And the only code that pops up is gov. pressure solenoid high. And I have to shift 1st to secon but I now have overdrive . I'm gonna change the sensors
External harness? Hhhmmm.... I am not sure just how much of that you would have to get, to replace the part going to the trans. Might need the entire engine/trans harness..... But no, don't need to drop the trans to swap it.
what you think about the pressure sensor? Replace it ?
