Universal CAT Fitment?
Old Jan 25, 2015 | 01:07 AM
dodgefan99's Avatar
dodgefan99
Default Universal CAT Fitment?
So I'm looking at this CAT mainly because it has a 3" inlet/outlet so when I put my new y-pipe on my new headers I can go straight into the CAT. My question is will it work. Its 500lbs. less vehicle weight capacity than OEM whatever that means but it says it will work up to 5.9L (Mines 5.2L). I need a single 3" CAT because I'm doing Pacesetter long tubes which are 3" with the Pacesetter off-road y-pipe which is also 3". I know I'll need some exhaust bungs btw.
Old Jan 25, 2015 | 05:59 AM
beeker's Avatar
beeker
Flowmaster catalog says it doesn't fit, may not heat up enough for the 5.2.
I used a 3inch IN/OUT Magnaflow for my setup.
If you search Magnaflow site for 2001 Dodge Ram (VAN) you will find 3inch IN/OUT cats specifically for our 5.2 and 5.9 motors, a different cat depending on which motor you have. Why not go with Magnaflow and that way you are sure it is correct size for your motor?
http://www.magnaflow.com/02catalytic...ct/49state.asp
Looks like the one for the 5.2 is $93 on Ebay
http://www.ebay.com/sch/i.html?_from...naflow&_sop=15
Old Jan 25, 2015 | 11:40 AM
dodgefan99's Avatar
dodgefan99
That's still not the correct one. That's for 2000-2001 RAM Van's. I've got a 98 Dodge RAM 1500 Sport.
Old Jan 25, 2015 | 12:15 PM
Spillage's Avatar
Spillage
"Universal fit"... 5.2/5.9... the cat doesn't know if it's a truck, van or skateboard... it also has no idea what year your truck was built... so long as it's in the 5.2/5.9 capacity range, it's happy.
The cat doesn't even know (or care) if it's Dodge, GM, or Ford.
Universal fit cat's are sold based on GVW and engine capacity... if your vehicle fits the spec range for the cat, you're good.
Old Jan 25, 2015 | 10:25 PM
dodgefan99's Avatar
dodgefan99
Just realized it looks like u have the same truck as I do and the same setup that I'm wanting to go to. Is that the CAT u used?
Old Jan 26, 2015 | 04:06 PM
beeker's Avatar
beeker
Yes, I got the one for Ram van for the 5.9. Only difference is the van has 3in in/out. For same exact motor as the van.
Old Jan 26, 2015 | 09:44 PM
Spillage's Avatar
Spillage
It might help if you fill in your vehicle info in your profile.
Are you regular cab short box?
4x4?
Pacesetter LT's, Pacesetter 'Y'-Pipe, Magnaflow #12279 Muffler, and Magnaflow #15035 Tailpipe, are a direct no cut fit in a RC/SB.
To get a Cat in this setup you need to trim the Y-pipe as far forward as you can, and trim the tailpipe as close to the hump over the axle as possible... then use a short Cat like the Magnaflow 94109... you have to stack everything as close together as you can and weld it up (no room for clamps)... put an O2 bung in the short gap between the cat and muffler.
FL not checking, I may have neglected to fit mine, and just put the O2 bung before the muffler with a plug saver... the cat might be in the shed just in case.
Old Jan 27, 2015 | 08:33 AM
dodgefan99's Avatar
dodgefan99
4x4?
Regular cab, short bed, 2wd
