Brake Problem
Old Jan 26, 2015 | 09:10 PM
adamj99's Avatar
adamj99
Default Brake Problem
ok when I try to stop the truck quickly it doesn't I can stand on the brake pedal and still wont stop the tires dead. I have changed all brake pads and still nothing, didn't change a thing I they don't need a bleeding next stop is rotors or brake booster any ideas??
Old Jan 26, 2015 | 09:59 PM
UnregisteredUser's Avatar
UnregisteredUser
How much pedal travel do you get when you're standing on it?
Does the pedal sink, or is the feel of it spongy?
Does the pedal effort seem excessive during normal braking?
Getting the Brake warning light in the instrument cluster?
Old Jan 26, 2015 | 10:44 PM
Did you turn, or replace the rotors when you did the fronts?
Old Jan 27, 2015 | 10:29 AM
Ramman18's Avatar
Ramman18
I had bad brakes for years and figured it was the larger tires and lack of 4 wheel disc (pads, rotors, and shoes all looked good.) Then I noticed one cylinder was leaking slightly so I had a shop replace both quick as I was heading on a trip the next day. WOW! Hasn't stopped like this since new. Cannot believe the difference. They must have been froze up for nearly ten years....
Old Jan 27, 2015 | 02:18 PM
adamj99's Avatar
adamj99
brakes don't feel spongy at all pedal travel is normal and no I didn't turn the rotors
Old Jan 27, 2015 | 08:39 PM
Then I would suggest you pull them, and have them turned, or replace them, if they are too thin to turn. They are probably glazed, and nothing you do elsewhere in the system will make the least difference..... Your front brakes do 70% of the work....
Old Jan 29, 2015 | 09:05 PM
adamj99's Avatar
adamj99
ya I got them booked in for Saturday to get turned
Old Jan 29, 2015 | 09:14 PM
issakar's Avatar
issakar
keep us updated on how things so
