Headlight wire assembly
Old Feb 1, 2015 | 10:32 PM
Blue Mopar01's Avatar
Blue Mopar01
Default Headlight wire assembly
I know there's a wiring assembly you can buy for our trucks to run higher output lights, LEd's and such. LMC has a heavy duty headlight harness 55-9505. Does that sound correct? The catalog says the harness can't be ran with day running lights and I have those on my truck. Anybody run a harness for higher output lights? I'm looking to run LED bulbs that's the source of my question.
Old Feb 1, 2015 | 11:54 PM
oxymoron29's Avatar
oxymoron29
Pretty sure any replacement LED headlight would have less wattage and therefore draw less amps than even a standard replacement halogen bulb, negating a need for an HD harness. FWIW the LMC is a decent option for the money and does in fact produce a noticeable gain in light output. Make sure to do your research on LED lights as well. I bought a pair of fogs off eBay and they turned out to be for nothing more than decoration.
Old Feb 2, 2015 | 08:30 AM
This ^^. If you go led, no need to upgrade anything. Led's draw much less current.
Old Feb 2, 2015 | 12:11 PM
Blue Mopar01
I figured since LED lights draw less power that I wouldn't need a harness but I see everyone say to install one so I was confused. I'll watch out for bad LED's too....to be totally clear I would get that harness if I ran ex. Sylvania silver star headlights or a higher drawing headlight? That's my understanding now
Old Feb 2, 2015 | 12:13 PM
If DRL's are required where you are, that is gonna make life a bit more interesting....
Old Feb 2, 2015 | 12:14 PM
Blue Mopar01
DRL? Sorry don't know the acronym there...you mean day running lights? I don't think ND requires them. Quite a bit of vehicles that don't have them. Never seen anyone get in trouble for them.
Old Feb 2, 2015 | 12:16 PM
Yep, Daytime Running lights. Quite frankly, I don't think I have ever heard of anyone getting a ticket for not having them working on vehicles that came with them......
Old Feb 2, 2015 | 12:23 PM
Blue Mopar01
Yep. I won't worry about that then.
