Shudder under load in lockup
#31
#32
#33
I would think at least 100 RPM, or in that neck of the woods..... Wonder if the O2 sensor saw all that extra O2 from the cylinder that wasn't firing, and richened up the rest, to try and compensate...... (which would also bump rpm up a bit.)
But, so long as you got the same drop across all cylinders, that's what you are really concerned about.
#34
Also, I put a test light on all injectors and they are all looking good.
#35
#36
#37
#38
I retested using better meter and they read 13 ohms.
A while back when I replaced the torque converter I never reinstalled the rear crossmember/shield, it sits just behind the transfer case, doesn't attach to it. You don't think that would cause the shudder? Never noticed it when trans was reinstalled without it. I will bolt it back in, just hasn't been highest on my to do list.
#39
#40
