got her to run but.....
Old Feb 4, 2015 | 07:16 PM
2015ram's Avatar
2015ram
Default got her to run but.....
i got my 99 5.2 to run you were right,i squeezed the crankshaft sensor wires between the block an tranny bellhousing,but now i got a small anti-freeze leak coming out the head gasket,my question is,torque specs? my final torque was a 105 ft lbs,any ideas? thanks again for the help
Old Feb 4, 2015 | 07:21 PM
AtomicDog's Avatar
AtomicDog
Final torque spec of 105 ft/lbs is correct. Are you sure its the head gasket and not a cracked head or the freeze plug in the head making it look like its the head gasket?
Old Feb 4, 2015 | 08:47 PM
2015ram's Avatar
2015ram
i removed the the belt tightner an alternator an its not a freeze plug an the heads were supposedly new so idk
mynah1's Avatar
mynah1
There's a freeze plug behind each head, it might be possible that during the installation of the CPS, the freeze plug may have been damaged. Probably from rust.
Take a mirror and flashlight and see if you can see the leak. You also have the heater hoses above that could give the impression that a water leak is behind the engine.
Best is to use a pressure tester, take it to 13-15 lbs and you should find the leak fairly easy.
Old Feb 4, 2015 | 09:01 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
You can get some dye you put in the radiator and then use a light and glasses to be able to see the leak. It works pretty good too.
Old Feb 4, 2015 | 10:18 PM
beau680's Avatar
beau680
So what kind of issues did you come across by not pinching the wires between block an tranny?
I'm curious I'm going to be doing install soon was kind of worried about that sensor
Old Feb 4, 2015 | 10:25 PM
Your best bet is to REMOVE the sensor FIRST, yank the engine, and install the sensor AFTER you have the engine in place. Yeah, it's a bear to get at there, but, better than having to buy a new one.
Old Feb 4, 2015 | 10:31 PM
2015ram's Avatar
2015ram
just take the time to remove it,you'll have enough things to keep out of the way,the way it is
Old Feb 4, 2015 | 11:06 PM
beau680's Avatar
beau680
Cool thanks
