need help
Old Feb 5, 2015 | 03:28 PM
Hammerjack435's Avatar
Hammerjack435
Default need help
I have a 2001 dodge ran 1500 5.2 liter gas. It started out I would always have to crank and crank the truck to get it to start. I replaced the fuel pump assembly. Ran fine for about 2 months I would drive the truck it would buck on the highway, thought was the trans going bad . after about month of driving get po306 code, number 6 cylinder not firing. I replaced wire, still same code pull valve cover looking bad rocker or stuck valve. Do compression test 165 each cylinder. I swapped a plug and wire code went away, My truck ran great for one day the next day. I go to start starts fine it has 50 pounds on fuel pressure when the truck is running on a fuel pressure gauge, gauge drops to 30 after about 8 minutes with engine off . The first start in the morning fine if I drive the truck and park it let it sit for 20 minutes or more , I have to crank and crank it to get it to start. truck run 100% on the highway around town , just if i let it sit it will not start If I shut it off and start in right back it starts. I have put a within the past 3 months fuel pump, new injectors, cap, wires, rotor, and plus cat is less than 5 years and 02 sensors were done when the cat was installed . anyone have any ideas ?
Last edited by Hammerjack435; Feb 6, 2015 at 01:54 PM. Reason: needs to make so everyone could understand it
Old Feb 5, 2015 | 03:33 PM
jham0077's Avatar
jham0077
I'd say pressure regulator maybe? Sounds like it may not be building pressure fast enough.
Old Feb 5, 2015 | 05:14 PM
Punctuation would be good, that's kinda hard to read......
But, if your fuel pressure is dropping off quickly, might be a leaky injector, that floods the motor when it sits. (leave it sit long enough though, and the gas evaporates off.)
Old Feb 5, 2015 | 05:39 PM
Icantbegintohelpbecauseihaveaheadachetryingtoreadw hatyouwrote.
Old Feb 6, 2015 | 01:55 PM
Hammerjack435
sorry I made it easier to read wanted to make sure I did not leave anything out
Old Feb 6, 2015 | 02:55 PM
What brand fuel pump? Have you fixed your plenum yet? (see the stickied thread) If you prime the pump a couple times, and then try and start it, will it fire right up? How about if you just hold down the gas pedal a little bit?
Old Feb 7, 2015 | 05:19 PM
Hammerjack435
What do you mean have I fixed the Plenum? That truck has a rebuilt motor that only has 15,000 miles on it If I hold a half throttle and crank it want to start the fuel pumps are SPECTRA PREMIUM fuel pumps
Old Feb 7, 2015 | 06:14 PM
Spillage's Avatar
Spillage
If it was rebuilt with the stock (metal) plenum plate, it could well have blown the plenum gasket (as they're well noted for doing).
A Delphi fuel pump is the way to go... others are hit or miss if you get any reasonable life out of them... some pack it in after a few months... I hate to say this, but with Spectra, "Premium" is the price, not the quality.
