coolant drain
Old Feb 6, 2015 | 04:05 PM
19cuda73's Avatar
19cuda73
New Member
Default coolant drain
Where is the drivers side 5.9l gas engine block coolant drain located? Is it behind engine mount?
Last edited by 19cuda73; Feb 6, 2015 at 04:06 PM. Reason: forgot to include something
Old Feb 6, 2015 | 04:51 PM
Moparite's Avatar
Moparite
It's behind the freeze plug at the back of the block.
Old Feb 6, 2015 | 05:22 PM
beeker's Avatar
beeker
you may knurl the threads pulling that plug out! Highly suggest you drain radiator using the drain ****, then remove lower radiator hose from the water pump, that should drain the block.
Old Feb 6, 2015 | 05:52 PM
That will only drain it down to a point, not completely.
Why do you want all the coolant out of the block?
Old Feb 6, 2015 | 06:22 PM
Moparite's Avatar
Moparite
Well it is a pipe thread but you should be ok unless you have major rust/corrosion issues in the block.
If you are clearing out dirty coolant there is also a pulg on the other side. Maybe replacing freeze plugs. ???
