cam bearings
Old Feb 9, 2015 | 02:34 AM
eddiekimberly's Avatar
eddiekimberly
Default cam bearings
Sorry to be short but can the cam bearings on a 5.2L 4x4 be changed without yanking the engine or tearing out the crank?
Old Feb 9, 2015 | 09:27 AM
Nope. Engine needs to come out to get the rearmost bearing.
Old Feb 9, 2015 | 11:27 AM
Moparite's Avatar
Moparite
Well i supose you could do it if you had enough room between the back of the block and tranz. There is a plug that goes in the hole at the back of the block. Any reason you are changing them? I just tore down a engine with 180K on it and the cam bearings where in great condition. They hardly ever need replacing.
Old Feb 9, 2015 | 06:52 PM
Largefarva's Avatar
Largefarva
^Agreed, can bearings very rarely need changing, but ya, to do them properly you should pull the engine, it will be less work, really.
Old Feb 9, 2015 | 07:04 PM
2damnyankee's Avatar
2damnyankee
Question ? Why would you want to just change Cam bearings? for what reason you believe they need to be changed?
Old Feb 9, 2015 | 08:46 PM
Ham Bone's Avatar
Ham Bone
Cam bearings in these magnums all look like **** its pretty well documented. However, they are almost always completely fine for use.
Old Feb 10, 2015 | 09:44 PM
eddiekimberly
MY bearings are fine, far as I know. I was asking for a friend. Not sure what his symptoms are. He just texted me and asked if it could be done. thanks for the replies.
