Working on my 2nd Gen. Suggestions appreciated
Old Mar 4, 2015 | 01:20 AM
  #31
zildjian3707's Avatar
zildjian3707
and after a new cat, a new plenum, new plugs, new distributor, need cables, new coil. My truck just still seems sluggish and i dont why. All these performance part to top it off and i dont just get it. The truck irritates me sometimes but i love it to death
Old Mar 4, 2015 | 08:48 AM
  #32
O2 sensors? Checked the cats?
Old Mar 4, 2015 | 03:46 PM
  #33
bcertain's Avatar
bcertain
Any clue where its going? Mine does that too, and never leaves a spot on the ground....
mine did the same for years. Found small seepage leak on back side of thermostat housing. Replaced it when I did thermostat and it went away. The old housing was really corroded.
Old Mar 4, 2015 | 09:24 PM
  #34
zildjian3707
ya both the o2s are new and the cat was replaced a year ago. maybe im just to used to the get up and go of a turbo diesel ha.
Old Mar 4, 2015 | 09:27 PM
  #35
Ya, bit of a difference in torque ratings there.
Old Mar 7, 2015 | 01:23 AM
  #36
zildjian3707
so ive discovered i have a blown gasket on one of my aftermarket headers, apparently....when i had the shop replace my cat, they stripped one of my header bolts putting it back on,,,which i guess after time blew out the gasket cause its gone or they never put back on. however, this cause a ticking sound on idle, cause its just air coming out of the header. Anyway could that cause a performance issue? im gonna fix it anyway
Old Mar 7, 2015 | 09:37 AM
  #37
Depends on where the O2 sensor is, if it is after the leak, yeah, that can cause issues.
Old Mar 7, 2015 | 09:28 PM
  #38
zildjian3707
ya the leak is right where the header connects to engine on cylinder 1
Old Mar 8, 2015 | 10:10 AM
  #39
That can give you trouble.
Old Mar 8, 2015 | 11:50 AM
  #40
zildjian3707
ya i figured. ill get it fixed
