Thermostat which one
Old Feb 15, 2015 | 08:28 PM
tazmaniac's Avatar
tazmaniac
Default Thermostat which one
My V10 is blowing luke warm upper hose hot lower cold so I see there is stats available from 160-200 degrees a majority of driving is going to be in the summer and most likey getting the Hemifever upgrade what would be a good temp to purchase even if I dont to the "fever" upgrade
Old Feb 16, 2015 | 10:33 AM
If you don't do the tuner, stick with stock temp. (195, I think) Hemifever, I do believe, recommends the 180 with his tunes.
Old Feb 16, 2015 | 02:50 PM
gertie240's Avatar
gertie240
Whichever stat you decide on, test it in a pan of almost boiling water so you don't install a bad stat and have to do it over.
Old Feb 16, 2015 | 03:08 PM
Moparite's Avatar
Moparite
You can run the 180* but you will notice a difference in the heat output in the winter. You are in Minnesota so you may want to keep the 195*.
Old Feb 16, 2015 | 06:02 PM
tazmaniac's Avatar
tazmaniac
the truck has never seen snow..well should never say never i did have to bring it to my shop to put a 2' level kit in .. waited for a -20 day so it wasnt slushy..and dont plan on driving it in winter
and yes ill boil it i keep forgetting that trick especially when stats are $23 for them
Old Feb 17, 2015 | 09:56 AM
onegoodmason's Avatar
onegoodmason
I buy T-stats right from the dealer . Never an issue . 180's are ok for warm climates , I can't use them unless I want to switch out for seasons .
Avoid anything "Fail-Safe" !! If you boil a new one , you will see why , they stick open first shot . I tried one , never again ! Ive read hundreds of complaints since !
Old Feb 17, 2015 | 10:20 PM
tazmaniac's Avatar
tazmaniac
Thank you
Originally Posted by onegoodmason
i buy t-stats right from the dealer . Never an issue . 180's are ok for warm climates , i can't use them unless i want to switch out for seasons .
Avoid anything "fail-safe" !! If you boil a new one , you will see why , they stick open first shot . I tried one , never again ! Ive read hundreds of complaints since !
Old Feb 18, 2015 | 01:19 PM
dodgefan99's Avatar
dodgefan99
Stant seems to be the favored around here. I bought a Jegs which theoretically is supposed to be better and it stuck open for the first 2 months and then decided it was going to work. I'll replace it when I do my plenum. I put a 180° in which is fine if its about 30°+ but when it's freaking freezing outside I wish I had a 195°
Old Feb 20, 2015 | 09:52 PM
bulldodgemoe's Avatar
bulldodgemoe
i have the hemi fever tune and a 180 thermo. as i also live in MN its TO LOW!!!! i block 2/3 of the radiator with cardboard just to get warm in this weather. driving interstate its about 200deg maybe.
Old Feb 20, 2015 | 11:53 PM
snowboundrmk's Avatar
snowboundrmk
The 180 gets me very cozy even when it's well below freezing. Having a regular cab probably plays part in it though.
