Thermostat which one
Old Feb 21, 2015 | 12:51 AM
horatio102's Avatar
horatio102
Stick with stock temp. Lower t-stat just makes it take longer to get up to operating temp, meaning it's less efficient.
Old Feb 21, 2015 | 11:01 AM
Moparite's Avatar
Moparite
??? Takes shorter amount of time because it's 20* colder. I've been running one for years with no issues.
Old Feb 22, 2015 | 12:42 AM
horatio102's Avatar
horatio102
A lower temp thermostat will help cool the cylinder temps down and allow for increased timing without detonation, however the factory program expects higher cylinder temps for a more complete burn. If your thermostat opens earlier, your PCM may think you're always in warmup mode - running extra rich until operating temp is reached.
https://books.google.com/books?id=Ek...20mode&f=false
Old Feb 22, 2015 | 11:47 AM
tazmaniac's Avatar
tazmaniac
wealth of knowledge here that's why I like this site!
Old Feb 22, 2015 | 12:25 PM
Moparite's Avatar
Moparite
It will throw a code also if it doesn't get up to operating temp. It will stay in open loop also. A 180* is above the cut off temp so you are ok. I have a black truck stuck in traffic with the ac on high with a ambient temp of 95* in mid day sun i'm glad i have the 180* stat
Old Feb 22, 2015 | 01:22 PM
Spillage's Avatar
Spillage
I have no issues with 180° either... the engine warms up at the same rate, it just gets to 180° and opens a tad sooner than if it had to continue to 190°.
At 180° it does take a little longer to heat the whole cab on a cold day, but it still does to an acceptable level... it's not like you'll be sitting in your cab in a speedo in the middle of winter, you're appropriately clothed for cold weather.
And as Moparite states, I'm much happier on a hot day.
