posi.rear end
Old Feb 15, 2015 | 10:13 PM
Diveright's Avatar
Diveright
Default posi.rear end
So I just got a 2000 dodge Laramie 4x4 slt. Does it have the posi. rear end
Old Feb 15, 2015 | 10:28 PM
AtomicDog's Avatar
AtomicDog
It's an option for that truck. Check your build sheet or jack up the rear of your truck, put the trans in neutral and turn one real wheel in the forward direction. If the wheel on the other side turns in the same direction, you have a posi rear.
Old Feb 16, 2015 | 07:49 AM
cjantczak's Avatar
cjantczak
should say under the hood of your truck or in the glove box of the truck. should be code dsa and chrysler called it anti-spin differential. or you could take your vin and email it to chrysler and theyll email you the build sheet.
