Idling Problem - Please help!
Old Feb 18, 2015 | 07:36 PM
bpearman's Avatar
bpearman
Default Idling Problem - Please help!
This is my first post to this forum. I hope somebody can help me.
2003 Ram 1500 - 5.7 Hemi
Sitting at idle it goes from 800 to 1200 rpms. When it goes up to 1200 it'll stay for about 5-10 seconds then back down to 800 for 5 seconds them back up to 1200. Does this constantly. Didn't start this until I replaced all 16 plugs/wires and cleaned throttle body and map sensor a week ago. Also sometimes just driving it'll start running real rough, no power at all and the red lightning bolt light will start flashing on the dash. I pull over to the side of the road, turn the switch off and then start truck again and it's fine. This has been going on for over a year. Somebody said it's the throttle position sensor, I bought one, said for that year and motor. Found out that the tps can't be replaced. It's built onto the side of the throttle body.
Any help please?!
Old Feb 18, 2015 | 07:45 PM
onegoodmason's Avatar
onegoodmason
Right church , wrong pew . You need the 3rd generation forum
Still , I will comment .
Possibly defective parts
Not sure if that throttle body has IAC or not , it may need to be cleaned
Was the battery disconnected when you cleaned everything ? It should have been .
Also somewhat characteristic of a bad 02 sensor
Good luck on the other side of the fence
Old Feb 18, 2015 | 07:52 PM
bpearman's Avatar
bpearman
Yeah I just realized that. Sorry. I have a 97 too. I re posted in Gen 3.
Throttle body was taken off and cleaned real good. No battery was not disconnected during any of it. And check engine light is not on so I can't check for any codes.
Old Feb 18, 2015 | 08:07 PM
Vacuum leak. Go back over your work.
Old Feb 19, 2015 | 07:15 PM
bpearman's Avatar
bpearman
The throttle works off vacuum too?
Old Feb 19, 2015 | 08:50 PM
A vacuum leak will confuse things, and sensor readings won't stay consistent, so, the engine will 'hunt' for the correct idle RPM. (and won't find it. )
