5.9L Magnum Engine tap right before each shift
Old Feb 20, 2015 | 04:26 PM
jb_wrigs32's Avatar
jb_wrigs32
Default 5.9L Magnum Engine tap right before each shift
First i want to start by saying that im new to the whole forum world. I read alot of them when searching on google and other things so I hope im going about this the right way. I am a truck technician professionally working on mostly Fords, but I am a Mopar guy at the core. I have a 2000 Dodge Ram 1500 5.9L Auto. I bought it as a project and I finally have it on the road. It still has a few issues but the one I'm not sure which direction to go with is this tapping noise I'm hearing right before each shift when the RPM's get alittle higher. I already know i have a ping some times (most likely plenum) but this isnt a ping. to me it sounds like lifters but im not sure if this is common or not. I have searched through alot of threads and havent found really what im looking for, or an answer that i think applies to my truck. If i could get some insight or maybe find out which direction i should go from you guys it would be great. Thanks in advance!
Old Feb 20, 2015 | 04:29 PM
Think I would be tempted to fix the plenum, seafoam the engine a time or two, do a thorough tuneup, and see if the problem didn't magically disappear. Spark knock, and lifter rattle sound surprisingly similar on these.
Welcome to DF!
Old Feb 21, 2015 | 12:39 PM
Moparite's Avatar
Moparite
Do you hear the sound when you rev it in park of is it only under load? Just noticed you are in Telford, PA. A local member! I'm over the bridge on the Jersey side. Just was wondering if the extreme cold we are having has anything to do with it.
Old Feb 23, 2015 | 10:40 AM
jb_wrigs32's Avatar
jb_wrigs32
I remember when I had my 98 Dakota with a 318 I would put 93 octane in when I would get a ping and it would go away for a little while before I had the oppourtunity to fix it. So I filled the tank with Premium and drove it around for a little while and it seemed to quiet it down an awful lot. I was extremely surprised because it sounded like a definite mechanical engine tap/knock. I heard the pinging before and it has never sounded the way that noise sounded to me but Im glad it seemed to clear it up for now. Well I guess its on the the old engine reseal. Im probably just gonna go for the gold and put every gasket on it, I know my front cover is leaking also. Thank you again for the replies and helping me out!!
